Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Journal File Error – Occurs ONLY if I change the name of the mesh › Reply To: Journal File Error – Occurs ONLY if I change the name of the mesh
JD_JN
Hi Nick,
Thank you so much for this!
I’ve managed to find the TUI command to change ids of face zones, which is what I’m trying to do. However, there is now a strange problem.
I tried to change the id of a face zone from being ‘430’ to ‘444’ [based on the comparison of ids between the 2 meshes], but when I do that, fluent meshing throws an error saying “Zone with id 444 already exists”.
However when I ask it for the zone with id ‘444’, it says “Invalid zone”. You can see this here:
zone id error
I also checked if there were any cell zones with this id, but sadly, I couldn’t find it there either. I’ve hit a brick wall again and have no idea what to do
