Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Forming Die Analysis – Solution Magnitude limit was exceeded error › Reply To: Forming Die Analysis – Solution Magnitude limit was exceeded error
Sampat Kumar
Hi Selcuk,
Will you please right-click on the error and click on the " Go to object". It will highlight the problem part of the model and help you to troubleshoot the problem. You can upload a screenshot of your model with the mesh tree and boundary conditions that you have applied.
Sampat
