Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Pressure direction on a shell › Reply To: Pressure direction on a shell
Kevin Gnanaraj
Thanks Peter, it was set to autoscale. The deformation looks more realistic.
Can you clarify whether I should be adding the freestream static pressure or not? I imagine that term decides whether inner pressure of the wing is accounted for in ANSYS
