Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Issues compiling UDF in ANSYS Fluent – UDF not being read correctly? › Reply To: Issues compiling UDF in ANSYS Fluent – UDF not being read correctly?
Federico
I just tested the UDF on my end, and it runs fine. Make sure your script .c is located in the working directory.
If the above is correct, I would argue this is probably an installation issue.
