Ansys Learning Forum Forums Discuss Simulation Fluids Modeling batteries (MSMD) with multiphase model enabled Reply To: Modeling batteries (MSMD) with multiphase model enabled
Murari Iyengar
Hi, the Multiphase model is not compatible with the Battery model in Fluent. If it works in a previous version, it is not recommended as there could be instabilites which is why it has been discontinued. Additionally, since it is not compatible in 22R1, you cannot use both models.Â
