Ansys Learning Forum Forums Discuss Simulation Fluids Issues compiling UDF in ANSYS Fluent – UDF not being read correctly? Reply To: Issues compiling UDF in ANSYS Fluent – UDF not being read correctly?
Federico
If you get a compiler error/warning, then you should troubleshoot this issue before the subsequent errors/warnings. Your UDF code looks fine to me, but for some reason, it appears that the script is not compiled correctly.
Are you following these steps here to Build and Load the UDF? 5.2. Compiling a UDF Using the GUI (ansys.com)
Do you get any errors when loading the UDF?
