Ansys Learning Forum Forums Discuss Simulation Fluids results data at the outlet to be input data at the inlet Reply To: results data at the outlet to be input data at the inlet
Supreetha J
You can make use of Profile file to do this. Kindly refer to the Ansys User's Guide 3.6. Reading and Writing Profile Files (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you.
