Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Solver Engine Error – unable to converge for non-linear analysis › Reply To: Solver Engine Error – unable to converge for non-linear analysis
July 24, 2023 at 6:00 am
Anand,
what plasticity model are you using ?
bi linear or multi linear ?
are you loading by displacement or force ?
i have simulated necking with a 2D axisymmetric model with multi linear plasticity and displacement control, displace it to a reasonable level, you should be able to calculate what this is, for say 30% strain.
your high distortion elements warning is probably in the necking region.
Track reaction force and if necking has occured, you will see a peak force that then drops.
