Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › How to correct direction of Translation joint for transient structural analysis? › Reply To: How to correct direction of Translation joint for transient structural analysis?
tirth.a2021
Well both actually. You see, primarily the disc would be rotating and the roller along with it. But since the roller is constrained inside the slot, it will impart vertical forces to the connecting rod so that it rotates with the disc, as well has slides inside the slot.
