Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ANSYS Licensing › Reply To: ANSYS Licensing
July 20, 2023 at 4:51 pm
Hi Feisal,
Goto: START > Expand Ansys 20xx Rx> search "Ansys Licensing Setting" (open as admin) and share a snapshot of it.
Please check and confirm if you are able to ping and telnet the server.
Go to the start menu and open the command prompt, and run the commands and send the screenshot of output:
- ping servername
- telnet servername portnumber (bydefault port number is 1055.)
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
- To ON telnet service go to start àsearch “Turn Windows feature on or off” àcheck box “Telnet Client” and click ok.
