Ansys Learning Forum Forums Discuss Simulation Fluids Forte_bowl_geometry.stl Reply To: Forte_bowl_geometry.stl
rahul.kumar
You should see the .ftsim file in the tutorial, load the file into Forte, then go to Geometry and Mesh > Export Geometry. You will have a stl file.
