Ansys Learning Forum Forums Discuss Simulation LS Dyna Ls-PrePost Post-processing problem Reply To: Ls-PrePost Post-processing problem
Ram Gopisetti
Hi, if you use the case means you are exploring the solution as the variable combination of different parameters,
why d you want to combine the results, what do you want to achive from it !
cheers, RamÂ
