Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › error code 127 › Reply To: error code 127
July 19, 2023 at 11:00 am
Is this the first time that you use the import CHEMKIN Mechanism feature?
Please perform the following test:
- Select methane-air under Mixture Material in the Species Model dialog box, then click on the "Ok" button.
- Set up the case with some sensible boundary conditions
- Initialise the flow and calculate for a few iterations to see if you are able to do this
