Ansys Learning Forum Forums Discuss Simulation General Mechanical how to assign energy probe using APDL command ? Reply To: how to assign energy probe using APDL command ?
ashish.khemka
I did check and you are not blocked from creating new posts. Please share a snapshot of the issue while creating a new post.
You can use NSEL command to select the nodes based on location (X, Y, or Z). Also, use of Named Selections Worksheet is an easy option to do so.
NSEL (ansys.com)
Named Selections (ansys.com)
Ashish Khemka
