Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDM not storing correctly › Reply To: UDM not storing correctly
July 19, 2023 at 9:10 am
If you didn't initialise the UDM when you initialised the model it could be anything.
You should be able to call the UDM inside the DEFINE_PROPERTY - once set it's just a value in the cell of interest like temp(erature) is in the documentation example.
