Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Laptop Compatability › Reply To: Laptop Compatability
July 19, 2023 at 7:51 am
The wider community can comment with a bit more leeway. However, staff can only refer you to the guidelines that Mrunali refers to.Â
The question isn't so much as will this run Ansys, but what do you want to be able to do using Ansys on your laptop? Because of the model size limitations on Student your requirements will be different to if you're doing research with a paid for licence.Â
