Ansys Learning Forum › Forums › Discuss Simulation › Fluids › variable pitch angle simulation of vertical axis wind turbine › Reply To: variable pitch angle simulation of vertical axis wind turbine
satyam
I don't understand what are you really trying to do? Pitch angle is the one set by you during geometry creation or rotating the domain through UDF. If you are randomly rotating the blade than you can write a udf to get the face-centroid with threads and then the angle.
