Rajeshwari Jadhav
Hi Feisal,
1. Are you able to ping/telnet the server using the command prompt?
2.  Go to C:\Program Files\ANSYS Inc\Shared Files\Licensing and open ansyslmd.ini to verify if the application is pointing to the right server, and to make any changes open it as admin.
Again rename the Ansys folder (%appdata%).
3. Close all the Ansys applications.
Go to Start--> search “Product and CAD Configuration 2023 R1” and run it as admin.
Follow the below steps: (while configuring products and unconfiguring products “select all” option)
  1. Install Required Prerequisites.
  2. Unconfigure Products & CADs.
  3. Configure Products & CADs.
4. Let me know the License Manager version, and share a screenshot if you face any errors.
