Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › ansys2022r1 parallel solution error › Reply To: ansys2022r1 parallel solution error
July 18, 2023 at 6:27 pm
Jim Day
I spoke to the developer of *INITIAL_ALE_MAPPING. He replied,
"I would say that the 1st integer in the mapping file is not properly read (either it has been created with a double precision executable or the file is somehow corrupted or the file has indeed been created by *BOUNDARY_ALE_MAPPING) ".
If that doesn't help, if you hold a commercial (non-academic) Ansys/LS-DYNA license, he suggested you provide the input and mes* files for debugging.  Do this by filing a Service Request or by contacting your Ansys Channel Partner.  You can't provide files via the Learning Forum.
