Ansys Learning Forum Forums Discuss Simulation Photonics Optimization Reply To: Optimization
Guilin Sun
Usually same issue the same solution. Make sure each sweep will not cause the monitor data matrix dimension change.
It seems your software is old version. The new version has clear warning (xx is the field component in the case below)
The results from the individual stimulations of '::model::monitor::XX' are of different sizes and could not be saved.
