Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Peculiar RCWA Simulation Results. Seems to be a bug? › Reply To: Peculiar RCWA Simulation Results. Seems to be a bug?
Guilin Sun
Then please check if the diffraction angles (theta and phi) are the same. The monitor should give E field for each diffraction order (defined by theta and phi).
