Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Not enough constraints appear to be applied. Simple shaft › Reply To: Not enough constraints appear to be applied. Simple shaft
atb
Hi Erik, it does not run, I am sure. I aborted the solution after the error. Not enough constraints. You can also see that I get solver pivot warnings. I'll look into the weak spring thing to see if it helps with my problem
