Ansys Learning Forum Forums Discuss Simulation Fluids Bad termination errors when using UDF’s on Fluent Reply To: Bad termination errors when using UDF’s on Fluent
Mark Fullerton
Thank you for the quick reply, I have run the setup without the UDF and it works fine, I think it is correctly compiled and loaded onto the case but I can't be 100% sure. I have tried using the built-in compiler but it gives a very similar error with just one bad termination message, followed by the program crashing.
