Ansys Learning Forum › Forums › Discuss Simulation › Photonics › extinction cross section for cylinder › Reply To: extinction cross section for cylinder
July 18, 2023 at 1:35 pm
Thank you for your response. My simulation is for a single wavelength and the source injection is normal to the symmetrical axis of the cylinder as shown in the previous image. I got the sweep results of scattering cross section for 3 different wavelengths as below:
and the analytical solution for extinction efficiency must be similar to below graph:
what should I do to get the same results? Meanwhile, how can I calculate the extinction efficiency, directly?
