Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with high penetration › Reply To: Problem with high penetration
sujeesh
Hello Nanda,
thank you for your prompt response. Regarding your question, no I have not modeled the seal as hyperelastic. I understand that it would be more accurate and i would implement it if i had the data at the moment. Nonetheless, if the stress/strain is too much for the seal i have modeled, it would probably break or deform plastically, but the solution should still be converging regardless if i am correct? This issue with too large mesh deformation would still persist I assume.
Thank you for the linked video. I will give it a watch and see if i can find something through that :)
Rohan
