Ansys Learning Forum Forums Discuss Simulation Fluids Model particle transport and depostion in a long capillary with very small radiu Reply To: Model particle transport and depostion in a long capillary with very small radiu
The membrane pore size only matters for the porous coefficients. If you assume particles don't build up so you don't create a physical cake DPM should be OK. If you want the cake, DPM isn't suitable, but Rocky is.
