Ansys Learning Forum Forums Discuss Simulation Fluids Error while compiling udf on linux Reply To: Error while compiling udf on linux
If it completes 8 in the /solve level then the next command can't run as there's no define at that level. Hence my comment about the / symbols. Running a journal section twice only makes a difference if it either changes a menu level or accidentally triggers something else.
We used to run setup files 3 times as those used to set models and bcs in such a way as not everything was set on the first pass. Ie buoyancy terms in the viscous panel aren't available until gravity is on operating conditions are after models in the file structure.Â
