Ansys Learning Forum Forums Discuss Simulation General Mechanical how to assign energy probe using APDL command ? Reply To: how to assign energy probe using APDL command ?
Sheref haddad
Hello @Dave,
I am writing APDL code inside the workbench, and I need to select some nodes in a plan at some distance from the origin in the Z axes. The problem is that distance is parametrized with the name H. How can I write this line of code?
greetings
