Ansys Learning Forum Forums Discuss Simulation Fluids How to input Turbulent Intensity as expression Reply To: How to input Turbulent Intensity as expression
Shivesh Sharma
I'm inputting the turbulent intensity as an expression because it varies with height. If I were to use a single valued constant, the turbulent intensity would not change with height, which means I wouldn't need to use an expression.
