Ansys Learning Forum Forums Discuss Simulation General Mechanical Not enough constraints appear to be applied. Simple shaft Reply To: Not enough constraints appear to be applied. Simple shaft
atb
Hi Erik .here is the extra info you requested. Please note that these bearing stiffness values are arbitrary (1e6 N/mm) but should be large enough. nevertheless, the issue persists.
