Ansys Learning Forum Forums Discuss Simulation Fluids Turbulence Intensity Expression (Inlet/Outlet) Reply To: Turbulence Intensity Expression (Inlet/Outlet)
n.goudarzi
Thank you for the response.
It is not single-valued. It is the TI value as a function of "y" coordinates.
The TI expression is defined on the inlet. We do not get a similar error for the inlet velocity expression. Any thoughts?
