Ansys Learning Forum Forums Discuss Simulation Fluids Help with expression Reply To: Help with expression
Maria Perez
It is closed, if I change X for 1[m] it works and gives me Pa as a result which is what I need. So the expression is not the problem. The problem is that the sqrt is taking negative values of X and that’s why it gives me an error. That’s why I specifically asked how to make the expression take only positive values of X.
