Ansys Learning Forum Forums Discuss Simulation Fluids Issue with UDF compilation Reply To: Issue with UDF compilation
The first line suggests a missing semi-colon.  Check the line above that too - once one of those goes missing you can get a load of false errors as the compiler flags things it thinks are on a single line of code.Â
