Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pressure drop Heat Exchanger Shell and Tube › Reply To: Pressure drop Heat Exchanger Shell and Tube
To add to Nick's comments. Please also post images of the cross section pressure loss (centre plane) and midway between two baffles. Did you model the tubes or use a porous media? Given the number of tubes in a typical HX you'll need a lot of mesh to resolve these.
