Ansys Learning Forum Forums Discuss Simulation Fluids Application failed to connect error Reply To: Application failed to connect error
Eunkyung Cho
I was following the 'steady flow past a cylinder' tutorial from the Ansys innovation courses. I do not have a specific reason for using CFD-post because I was simply following the tutorial. Since I am in the learning phase of this program, I would like to know how CFD-post works as well.
Additionally, I believe the CFD post is correctly installed because I can open it in stand-alone mode.
