Ansys Learning Forum Forums Discuss Simulation Fluids Application failed to connect error Reply To: Application failed to connect error
NickFL
Is there a reason you want to use CFD-Post? Because that is what results will open. Most of the post-processing can be done in Fluent. As for the error, is CFD Post correctly installed? You should be able to open it in stand-alone mode (from windows start menu).
