Ansys Learning Forum Forums Discuss Simulation Fluids How does Ansys calculate the surface deposition rate (kg/m^2s)? Reply To: How does Ansys calculate the surface deposition rate (kg/m^2s)?
Hilmi Johari
Are there any other link other than the link given to access how the surface deposition rate is calculated? I cannot access the link. A reviewer wanted to know exactly how it is calculated.
Thank you.
