Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence Issues in Hyperelastic Material – Non linear Structural Analysis Reply To: Convergence Issues in Hyperelastic Material – Non linear Structural Analysis
Dhanush Kumar K K
First of all, thank you, Peter. For all your suggestions which I found very helpful in older feeds/threads.
I could make a pure hex mesh with solid 185 & further by slicing the solid. I used MultiZone as I couldn't get sweep to mesh properly. Still the solution is not converging and high distorting elements are detected.
Also, after I apply the shared topology in spaceclaim/DM, the solid is not visible in mechanical, it says the updated model uses a different unit, which I checked.
