Ansys Learning Forum Forums Installation and Licensing Ansys Products Meshing thick and thin bodies in Ansys mechanical Reply To: Meshing thick and thin bodies in Ansys mechanical
mjmiddle
As Ashish mentioned, one method is to model the thin body as a surface body with a thickness assigned. There will be gaps between the solid bodies. For the contacts you can set “shell thickness effect” to yes, or specify a gap offset.
If you want to model as a thin solid, you would not want to use a tetra mesh on this body since it will produce a lot of elements. You would want to make the body sweepable if it is not already, and use a swept or multizone method.
You wrote “in the actual model the shape in much more complex that can not be modeled as 2D shell elements.” I do not understand this statement. Can you explain more? Are their some tiny features within the thin thickness that are not the same on both sides of the thin body (source and target sides)? These thin bodies usually don’t have reasonable room inside for any features smaller than the thickness, so source and target sides would be the same. If there are source and target sides, then the body is sweepable or could also be simplified to a shell body as Ashish recommended.
