Ansys Learning Forum Forums Discuss Simulation General Mechanical how to determine the total volume for a specific temperature range Reply To: how to determine the total volume for a specific temperature range
dlooman
If you are running a pure thermal analysis the command should be file,file,rth.  The results can be seen in Solution information:  Post Output as shown below.  Or if you right click on Solution (A6) then Open Solver Files Directory, they are in the file, post.out
