Ansys Learning Forum › Forums › Discuss Simulation › Fluids › A rigid body being moved by water within a dynamic mesh. › Reply To: A rigid body being moved by water within a dynamic mesh.
Federico
I am not convinced that you will see "vibrations" for this setup. Piston velocity may oscillate slightly but should always point to the same direction.
