Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Fields from Parametric Sweep with copied mesh › Reply To: Fields from Parametric Sweep with copied mesh
nina.megier
In change variable values I have only one choice, which is not the value for the variation I have chosen in view results.
If I choose the first variation with n=1 in Optometrics->View Results, then the field are there. So apparently only the fields for the 1. varaiation were calculated/stored.
