Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Using dataset for frequency dependent Renormalization impedance › Reply To: Using dataset for frequency dependent Renormalization impedance
Paolo Squadrito
The dataset i defined are in the same design, i even try to do as you said adding an expression with a new the dataset not present in the design and i do not get any dataset window. This is the expression i used where ds1 is the NEW dataset and i get the same error
