Ansys Learning Forum Forums Discuss Simulation General Mechanical Rocky and Mechanical two-way coupling Reply To: Rocky and Mechanical two-way coupling
Tasos Zacharakis
Hello Dayana,
In Ansys Workbench, you can drag & drop systems over one another so to share and transfer results from one system to another.
Rocky is fully integrated with Ansys Workbench, meaning that you can perform various coupled analyses with other physics such as structures and fluids, depending on the nature of the problem that needs to be solved without the need of using external software.
In the picture below, you can see an example of a workflow of coupled analyses with Rocky.
You can find examples of coupled analyses with Rocky on Youtube.
Hope that helps,
Tasos
