Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modeling internal using porous media model – fluid get stuck under the internal › Reply To: Modeling internal using porous media model – fluid get stuck under the internal
July 14, 2023 at 6:59 am
Thank you Rob for such a quick answer. More or less it looks like this. I have a similar problem with different meshes so I think that it could be more set up. Generally, the gas phase does not cross the porous media model in some regions.
