Ansys Learning Forum Forums Discuss Simulation Electronics Using dataset for frequency dependent Renormalization impedance Reply To: Using dataset for frequency dependent Renormalization impedance
Chinmay T
Are you using the dataset in the same design where you have added it?
If the dataset is not added into the same desing and you are trying to enter the expression directly then dataset window will pop up where you can add the dataset values.
Thank you,
Chinmay
