Ansys Learning Forum Forums Discuss Simulation Photonics File Size in Layout Mode larger than Memory Layout Size in Analysis Mode Reply To: File Size in Layout Mode larger than Memory Layout Size in Analysis Mode
Sathursan
Hi Amrita,
I have tried that but the file size is still more significant than it should be in layout mode. Most of the clear commands in Lumerical are for the data saved when the simulation file is in analysis mode. Since this is not the case, I do not know why this is happening. There are no saved data in sweeps that I performed on the file either so it can't be due to that either. I tried running the simulation to see if that changes the file size and all it does is adds on to the existing file size (9.1 Gb to 10.9 Gb where it should be 900 Mb to 3.2 Gb).
I am unsure whether there is something that I am missing or a bug with Lumerical.
Thanks,
Sathursan
