Ansys Learning Forum Forums Discuss Simulation Photonics File Size in Layout Mode larger than Memory Layout Size in Analysis Mode Reply To: File Size in Layout Mode larger than Memory Layout Size in Analysis Mode
Amrita Pati
Hi Sathursan,
Thank you for contacting us. You may use certain clear functions to reduce the size of the simulation. For example, if you have mode expansion monitors in your simulation file, you can use the clearmodedata command to clear all the associated mode data. You can also try using other functions such as cleardcard or clearanalysis to see if that helps reduce the size of the simulation. I will suggest you to look at Lumerical's alphabetial list of script commands, you may find a number of commands starting with "clear" that might be helpful.
Amrita
