Ansys Learning Forum Forums Discuss Simulation Fluids Error while compiling udf on linux Reply To: Error while compiling udf on linux
Shyam Prasad V Atri
never mind i found the problem
the marked section has to be different for linux. it asks for header files saperatrtely and I don't have any new header files. but I would like to report this as a problem.
in windows, the above tui script works without any problems. I get the desired output but in linux the TUI script needs to be changed. and another big issue with linux is the GUI is not good and we are advised against using it.
