Ansys Learning Forum Forums Installation and Licensing Ansys Products Translucent internal surfaces+Radiation model Reply To: Translucent internal surfaces+Radiation model
Gu Xuan
Thank you for your reply.
>May I know the fluent version you are using.
Yes! I used ver. 2021 R2.
I studied these parts before. My case may be different.
In my model, the mediums a and b are the same.  As 5.3.6.7.1 described, it seems that the refractive index   and   were important to change.
And if the wall is 0 thickness, the refractive index is not important.
If the wall has thickness, the absorption coefficient can be set to simulate raditation transmission and absorption.
But my case, the wall is 0 thickness, and medium a , b is the same. So how to do it?
